Script to send alerts when the Interface get new IP from DHCP
demichel2
Hi All,
I have some branch offices with a Cable ISP company with dynamic IP address,   I'm trying to create a script to automatically send an email if the interface get a new IP address if the interface get the previous IP do not send an email .
So far this is the script I created :
event manager applet TEST2
event syslog pattern "Interface FastEthernet1 assigned DHCP"
action 1.1 cli command "enable"
action 1.2 cli command "show int FastEthernet1 | i Internet address"
action 1.51 regexp "Internet address is 9.9.9.9 /30" "$_cli_result"
action 1.6 if $_regexp_result eq "0"
action 2.0 mail from testevent@anydomain.com to emai@anydomain.com subject "NEW IP ADDRESS " server SMTP.ANYDOMAIN.COM body "$_syslog_msg"
action 2.1 end
The only issue with the script is that if the interface get a new IP address I need to update the script in action 1.51 regexp with the new IP address so next time the interface change the IP compare with the variable Internet address is ...
Thank you,
Joe Clarke
There are a number of ways to do what you want.  A file on flash is probably the easiest given it will persist across reboots.
event manager applet check-ip
 action 1.0 cli command "enable"
 action 2.0 handle-error type ignore
 action 3.0 file open fd flash:myip.txt r
 action 4.0 if $_error ne FH_EOK
 action 4.1  set currip "0.0.0.0"
 action 4.2 else
 action 4.3  file gets fd currip
 action 4.4  file close fd
 action 4.5 end
 action 4.6 handle-error type exit
 action 4.7 cli command "show int Fa1 | inc Internet address"
 action 4.8 regexp "Internet address is ([0-9\.]+)" "$_cli_result" match myip
 action 4.9 if $myip ne $currip
 action 5.0  mail from testevent@anydomain.com to emai@anydomain.com subject "NEW IP ADDRESS " server SMTP.ANYDOMAIN.COM body "$_syslog_msg"
 action 5.1  file open fd flash:myip.txt w
 action 5.2  file puts fd nonewline $myip
 action 5.3  file close fd
 action 5.4 end
Joe Clarke
 action 4.2 else
 action 4.5 end
 action 5.4 end
I'm getting  this error *Jul  1 19:31:01.152: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: myip
Never mine ... I just have the incorrect interface
