Setting Access controls to groups in CM 4.0????
viswanathan123
Hai all,
I using LMS 2.5 on win2k server with all latest updates.
Also i tried LMS 2.5 with ACS 3.3. It is working fine but still some problems.
Here are the list.
1.I am able to create Groups in CS 3.0 and devices are populating according to rules. But my doubt is if i am going to integrate with ACS i need to create all possible groups before integration ????
2. In CM 4.0, Online help Using Topology service -> Topology Groups -> Using Topology groups . It is mentioned that "we can set access control permission for Campus users" after teh 4th step.
But when i try to create that it is not appearing is it a bug ??
Then how can ia ssign the user roles to my created groups ???
My aim is to create several Topology groups and create each user.So that each user should view only his device map .
Any suggestion for this???
I am ready to use ACS 3.3 for this purpose.
Expecting reply.
amritpatek
Level 6
Level 6
You can create groups after intergartion also. Just need to make add in ACs too.
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_user_guide_chapter09186a00803f3697.html#wp1033959
