Setting up NTP on an 857
CombinedEffort
Hi all,
I'm probably being thick here, but I cannot set an ntp server reference on my Cisco 857:
cisco#sh ver
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
cisco#ntp ?
% Unrecognized command
cisco#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
cisco(config)#ntp ?
What am I missing (apart from several hours sleep)?
Rich.
Leo Laohoo
850 doesn't support NTP.  Try using "sntp server ".
If my post is helpful, may I request if you can rate it? Thank you very much.
Leo Laohoo
