Setting up RME Archive configs
skwood
I have a number of problems, but will do one at a time. To gain access to some devices, you use telnet and others ssh1. The telnet devices are OK, but the ssh1 devices are failing. Where do I tell RME which method to use? Version 4.05
Joe Clarke
It depends on what you're trying to do. For configuration jobs, the protocol order can be specified under RME > Admin > Config Mgmt > Transport Settings. For Software Management, this done under RME > Admin > Software Mgmt > View/Edit Preferences.
Note: SSH version is determined dynamically if the device supports SSH, and you wish to use SSH as a transport protocol. Both SSHv1 and v2 are supported.
