06-15-2020 08:19 AM
I have a very standard setup. SG300 52 poe, vlan1 and vlan3. Polycom phones on Vlan3. 4 or 5 ports on the switch aren't working as expected.
I plug the Polycom phone to the bad switch port and it powers but then displays Dhcp failed. Every other port on the switch works except those 4 or 5. No logical explanation. I connect the phone to the other ports and it works. It has a dial tone. Any suggestions? Can couple ports go bad on the switch? Thanks.
Solved! Go to Solution.
06-15-2020 10:23 AM
06-15-2020 09:56 AM
- Couple of ports can easily go bad. Try some other equipment on the suspicious ports such as laptop (e.g.) ; check the results.
M.
06-15-2020 10:23 AM
