Just a little confused here..... I can do the exact commands in the EEM script directly and it does what I need it to do. However, the script, when triggered, with the "EXACT" same commands sometimes works / sometimes not. Arrrgghhh! So, here is the script:
event manager applet Virtual-PPP1_Ping
event syslog pattern "TRACKING-5-STATE: 1 ip sla 1 reachability Up->Down"
action 010 cli command "enable"
action 011 cli command "clear vpdn tunnel l2tp all" pattern "[confirm]"
action 012 cli command "confirm"
action 020 cli command "conf t"
action 030 cli command "int Virtual-PPP1"
action 040 cli command "shut"
action 045 wait 3
action 050 cli command "no shut"
action 060 cli command "end"
Basically what happens is that the Virtual-PPP1 interface sometimes loses it's ip address through IPCP. So, the L2TP tunnel is still up, BUT, the Virtual-PPP1 interface loses it's assigned IP when I check the interface as it shows "unassigned".
Ideas?
Thanks for the help.
Jason
Try this instead:
event syslog pattern "TRACKING-5-STATE: 1 ip sla 1 reachability Up->Down" maxrun 30
action 011 cli command "clear vpdn tunnel l2tp all" pattern "confirm"
action 045 wait 3
