sla command and track objects v12.4(15)
networkingib
Level 2
Level 2
Hi all,
I have upgraded my cisco router 857 to version 12.4(15)T3.
And when I try to use the track command it doesn't recognise it:
C857(config)#track 1 rtr 1 reachability
% Invalid input detected at '^' marker.
C857(config)#
C857(config)#track ?
% Unrecognized command
C857(config)#track
I have created a sla object:
ip sla 1
icmp-echo X.X.X.X source-interface Dialer0
timeout 3000
threshold 3
frequency 3
ip sla schedule 1 life forever start-time now
And now I would like to use it to check the default route:
C857(config)#ip route 0.0.0.0 0.0.0.0 dialer 0 track ?
<1-500> tracked object number
C857(config)#ip route 0.0.0.0 0.0.0.0 dialer 0 track 1
I can use track objects but I can't create them. 😞
The problem is that I don't know how to associate sla 1 with track 1 in this new version since the router doens't recognise track command.
Could anyone help me?
Thanks and Regards, Fernando.
Joe Clarke
IP SLA object tracking is not supported on the 857.
Wow! Really? 😕
What I don't understand is why I can use track objects but I can't create them.
Well, I would have to look for a diferent way to do what I want.
Anyway, Thanks.
Regards, Fernando.
You can use the Feature Navigator to see which features are supported in different IOS versions and platforms (http://www.cisco.com/go/fn/ ). The smallest platform to support tracking is the 1700 series.
Thanks!
