SMTP port change from default
dannyg
hi all,
can i change the default SMTP port in LMS2.6 version or above from port 25 to port xxx?
Joe Clarke
No, the SMTP port of tcp/25 is hardcoded.  As a workaround, would it be possible for you to setup port mapping on the LMS server (or another host) to forward tcp/25 to another host/port?
