SNMP for monitoring IP SLA
sercopi
Hi all,
I need to monitoring IP SLA on board of a Cisco Device.
I have a question: Cisco device support only snmp trap?
For example as I saw:
snmp-server enable traps ipsla
snmp-server host x.x.x.x version 2c community xxxx
or I can use also snmp call from my monitoring system?
At today I used check_cisco_ipsla.pl but the output don't satisfy my self:
[root@sat-103956-01 plugins]# ./check_cisco_ipsla.pl -c phoenix-mng -H 10.67.7.8 -i ALL
IP SLA status: OK | Total-Time=0
Best Regards
Giovanni Davide Saccà
Tony T.
Giovanni-
When attempting to add a SNMP trap for IP SLA try using the following command: ip sla logging traps
You can add that in global configuration.
Kind Regards,
Tony
