SNMP for tracking
aryanadonis
Level 2
Level 2
We enabled a static default route with tracking option that checks a tcp
port 80 service on the Internet using IP SLA. If we enable SNMP traps for IP SLA, what type of SNMP-trap message should we expect whenever the IP SLA changes state?
Joe Clarke
You will see traps from the CISCO-RTTMON-MIB. Depending on the type of failure and IOS version, you may see rttMonNotification, rttMonTimeoutNotification, etc.
Thanks jclarke,
Do you have the specific SNMP-trap message that will be coming from CISCO-RTTMON-M? IE what our HP OpenView server will see coming from the routers.
I don't have examples, but the traps are all listed in the CISCO-RTTMON-MIB. I've already listed two trap names that can be sent to HPOV. If you have the CISCO-RTTMON-MIB loaded in OV, you should see the trap varbinds decoded properly.
