SNMP MIB for DSL interface status
Bernard Magny
I'm looking for the SNMP MIB that would display the current DSL sync speed of a 877 router.
I can see it by using the command :
show dsl intface
part of the output I get is this:
Interleave Fast Interleave Fast
Speed (kbps): 7456 0 448 0
Cells: 111023360 0 17102308 0
Reed-Solomon EC: 50338 0 1404 1108
CRC Errors: 65084 0 1245 1127
Header Errors: 25399 0 1366 1211
in this example my DSL download sync speed is 7456 Kbps. I was wondering if there is a MIB that would give me this information.
David Stanford
The following MIB should do it, if it is supported on your device:
.1.3.6.1.2.1.10.94.1
adslLineMib from the ADSL-LINE-MIB
