SNMP monitoring of RPS2300 power system on 3750E
turklandbank
Hi there.
I am trying to monitor RPS2300 redundant power system connected to 3750E stack.
Using console connection with " show env " command i can see all the information about the RPS2300 redundant power system as follows:
SW Status RPS Name RPS Serial# RPS Port#
1 Active CiscoRPS CAT1131VG40 1
2 Active CiscoRPS CAT1131VG40 2
3 Active CiscoRPS CAT1131VG40 3
RPS Name: CiscoRPS
State: Active
PID: PWR-RPS2300
Serial#: CAT1131VG40
Fan: Good
Temperature: Green
RPS Power Supply A: Present
PID : C3K-PWR-750WAC
Serial# : DTN1126E0C9
System Power : Good
PoE Power : Good
Watts : 300/450 (System/PoE)
RPS Power Supply B: Present
Serial# : DTN1126E0CG
System Power : Good
PoE Power : Good
DCOut State Connected Priority BackingUp WillBackup Portname SW#
1 Active Yes 6 No Yes c3750_stack01 1
2 Active Yes 6 No Yes c3750_stack01 -
3 Active Yes 6 No Yes c3750_stack01 -
4 Active Yes 6 No Yes c3750_stack02 1
5 Active No 6 No Yes <> -
But i could not monitor any value listed in console using SNMP. I could not find any MIB table regarding RPS2300 health. When walked on MIB file CISCO-ENVMON-MIB, it even looks, no RPS is connected:
ciscoEnvMonSupplyStatusTable(5)
ciscoEnvMonSupplyStatusEntry(1)
ciscoEnvMonSupplyStatusDescr(2)
1059 Sw1, PS1 Normal, RPS NotExist
2060 Sw2, PS1 Normal, RPS NotExist
3059 Sw3, PS1 Normal, RPS NotExist
ciscoEnvMonSupplyState(3)
1059 normal (1)
2060 normal (1)
3059 normal (1)
ciscoEnvMonSupplySource(4)
1059 ac (2)
2060 ac (2)
3059 ac (2)
Is there a way or a new MIB to monitor RPS2300 via SNMP ???
Thanks in advance...
Regards..
Bulent.
didyap
Level 6
Level 6
There is a syslog message at ALERT level when the internal power supply is removed or is detected as being faulty.
If you have a 3560e connected to RPS2300, you may try "power supply off" and then see the syslog message. Also, "sh env power" should indicate the status of the power supply and "sh env rps" will inform if the RPS is backing up the switch.
Did you try to walk the CISCO-ENTITY-FRU-CONTROL-MIB ?
I am wondering if it could be reported correctly from this mib, it would be good if somebody could test it.
Fabien
Pacerfan9_2
I ran into the same issue on a 2960S and was able to figure it out. I was able to monitor using an SNMP query using walk type, get next, OID = .1.3.6.1.4.1.9.9.13.1.5.1.2.
The OID for switch I was testing ended up being .1.3.6.1.4.1.9.9.13.1.5.1.2.1006. I am not sure if the ending value is persistent or will change after a reboot. I know on the 3560-X the ending value may change after a reboot when monitoring two modular power supplies.
Below is the possible SNMP output I was able to detect.
Switch Internal Power Supply Status
Redundant Power Supply Status
SNMP Output =
Powered
Powered
Sw1, PS1 Normal, RPS Normal
Powered
Not Powered
Sw1, PS1 Normal, RPS unknown
Powered
Not Connected
Not Connected
Powered, Active
Sw1, PS1 Faulty, RPS Normal
ReConnected
Powered, Active
Powered
Powered, Standby
Powered
Powered, Active
Powered
Powered, RPS in use by another switch
Management Commands
Using Cisco 2960S, I am assuming similar function on 3560/3750 E or X routers/switches
show env power
show env rps
power rps 1 port 1 mode standby
Place RPS into standby after power has been restored to internal power supply. No reboot required
power rps 1 port 1 mode active
Place RPS into active (ready) state so it is able to supply power in the event of another failure. No reboot required
Using Cisco 2960, I am assuming similar function on all other non E or X routers/switches
Place RPS into standby after power has been restored to internal power supply. Will automatically reboot switch
