SNMP Monitoring of SG350 weird behavior
Martin H. BN
Hello Community,
i'm responsible for the network monitoring and ran into a problem with monitoring the Cisco SG350 Series Switches with zabbix.
From time to time i get no data from the switch, but not from the complete switch or interface but just for one datapoint.
The logfile of zabbiz then shows something like
***.net.if.in.discards[ifInDiscards.19] became not supportetd: No Such Instance currently exist at this OID
a few minutes later  the logfile shows
***.net.if.in.discards[ifInDiscards.19] became supported
During the time no data will be recorded for in discarded packets while all other like bits send / received, Errors in / out, and so on are still available.
This can happend for every data like Bits Send/Received, Error In/Out, Discard In/Out and it happens randomly for different interfaces on all SG 350 Series Switches.
SNMP Config on SG350:
snmp-server server
snmp-server community ******* ro view Default
This problem strangely only occures with the SG350 Switches. I never had any simmilar problem withm any other Cisco Switch like the 2960, 3560, or Nexus Series Switches.
Any help / hint would be aprecciated
“The universe doesn't allow perfection.”
― Stephen Hawking
0 Replies 0
