07-21-2013 11:37 PM
Hi everyone,
We're trying to read CPU & MEM values from ASR1006 equipment. Obviously the old OIDs are not supported on this platform. This is what we have found by going through the snmp object navigator. (I assume .2 is the ESP, .3 is the RP, .4 & .5 are the SIPs). But the values we get from the command line are slightly different than what we get through snmp. Has anyone done this before? What OIDs do you use?
CPU:
1min: cpmCPULoadAvg1min
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.24.2; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.24.3; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.24.4; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.24.5; Value (Gauge):
5min: cpmCPULoadAvg5min
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.25.2; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.25.3; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.25.4; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.25.5; Value (Gauge):
15min: cpmCPULoadAvg15min
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.26.2; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.26.3; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.26.4; Value (Gauge):
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.26.5; Value (Gauge):
Memory:
cpmCPUMemoryUsed
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.12.2; Value (Gauge): KiloByte
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.12.3; Value (Gauge): KiloByte
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.12.4; Value (Gauge): KiloByte
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.12.5; Value (Gauge): KiloByte
cpmCPUMemoryFree
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.13.2; Value (Gauge): KiloByte
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.13.3; Value (Gauge): KiloByte
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.13.4; Value (Gauge): KiloByte
Name/OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.13.5; Value (Gauge): KiloByte
Best Regards,
Babak
05-11-2015 08:48 AM
Hi Babek,
On the contrary I believe the last value of the IOD related to the slot number.
We have 2 SIP, One in slot 1 (the top most in our 1006) and One in slot 3.
These are the IODs we use for these:
.1.3.6.1.4.1.9.9.109.1.1.1.1.13.7 = SIP0 - Free Memory
.1.3.6.1.4.1.9.9.109.1.1.1.1.13.5 = SIP2 - Free Memory
Hope this helps
Peter Haas
05-14-2015 04:34 AM
Calculating Memory Utilization:
cempMemPoolUsed 1.3.6.1.4.1.9.9.221.1.1.1.1.7
cempMemPoolFree 1.3.6.1.4.1.9.9.221.1.1.1.1.8
Memory Utilization = cempMemPoolUsed /( cempMemPoolUsed + cempMemPoolFree)] * 100
Recommended threshold for Memory Utilization is 80%
