11-23-2016 01:45 AM
Need the SNMP Trap Definition for Firepower.
See Traps with 1.3.6.1.4.1.9.9.826.6.1 (1.3.6.1.4.1.9.9.826.0.1)
Have a look on the attachment.
03-06-2017 11:40 PM
"If your network management system requires a management information base file (MIB), you can obtain it from the ASA FirePOWER module at /etc/sf/DCEALERT.MIB."
Quoted from http://www.cisco.com/c/en/us/td/docs/security/firesight/541/firepower-module-user-guide/asa-firepower-module-user-guide-v541/Intrusion-External-Responses.pdf
Please let me know if this helps.
Sergei.
08-24-2017 02:34 PM
I search the Firepower sensors, and there is a folder for the MIBS.
/usr/share/snmp/mibs
It lists a long list of MIBS types. I will be trying some of them in our monitoring tool, and see if it works.
09-18-2018 01:35 AM
Hello
I am trying to get some basic information about Firepower Managemet Center.
The problem I am having is that it is installed on a ESXi (it is virtual),
How can I get those basic values (like CPU, Temperature...).
These are the mibs which it has:
root@FireSIGHT-Management:/usr/share/snmp/mibs# ls -l
AGENTX-MIB.txt
BRIDGE-MIB.txt
DISMAN-EVENT-MIB.txt
DISMAN-EXPRESSION-MIB.txt
DISMAN-NSLOOKUP-MIB.txt
DISMAN-PING-MIB.txt
DISMAN-SCHEDULE-MIB.txt
DISMAN-SCRIPT-MIB.txt
DISMAN-TRACEROUTE-MIB.txt
EtherLike-MIB.txt
HCNUM-TC.txt
HOST-RESOURCES-MIB.txt
HOST-RESOURCES-TYPES.txt
IANA-ADDRESS-FAMILY-NUMBERS-MIB.txt
IANA-LANGUAGE-MIB.txt
IANA-RTPROTO-MIB.txt
IANAifType-MIB.txt
IF-INVERTED-STACK-MIB.txt
IF-MIB.txt
INET-ADDRESS-MIB.txt
IP-FORWARD-MIB.txt
IP-MIB.txt
IPV6-FLOW-LABEL-MIB.txt
IPV6-ICMP-MIB.txt
IPV6-MIB.txt
IPV6-TC.txt
IPV6-TCP-MIB.txt
IPV6-UDP-MIB.txt
LM-SENSORS-MIB.txt
MTA-MIB.txt
NET-SNMP-AGENT-MIB.txt
NET-SNMP-EXAMPLES-MIB.txt
NET-SNMP-EXTEND-MIB.txt
NET-SNMP-MIB.txt
NET-SNMP-MONITOR-MIB.txt
NET-SNMP-PASS-MIB.txt
NET-SNMP-SYSTEM-MIB.txt
NET-SNMP-TC.txt
NET-SNMP-VACM-MIB.txt
NETWORK-SERVICES-MIB.txt
NOTIFICATION-LOG-MIB.txt
RFC-1215.txt
RFC1155-SMI.txt
RFC1213-MIB.txt
RMON-MIB.txt
SCTP-MIB.txt
SMUX-MIB.txt
SNMP-COMMUNITY-MIB.txt
SNMP-FRAMEWORK-MIB.txt
SNMP-MPD-MIB.txt
SNMP-NOTIFICATION-MIB.txt
SNMP-PROXY-MIB.txt
SNMP-TARGET-MIB.txt
SNMP-TLS-TM-MIB.txt
SNMP-TSM-MIB.txt
SNMP-USER-BASED-SM-MIB.txt
SNMP-USM-AES-MIB.txt
SNMP-USM-DH-OBJECTS-MIB.txt
SNMP-VIEW-BASED-ACM-MIB.txt
SNMPv2-CONF.txt
SNMPv2-MIB.txt
SNMPv2-SMI.txt
SNMPv2-TC.txt
SNMPv2-TM.txt
TCP-MIB.txt
TRANSPORT-ADDRESS-MIB.txt
TUNNEL-MIB.txt
UCD-DEMO-MIB.inc
UCD-DEMO-MIB.txt
UCD-DISKIO-MIB.inc
UCD-DISKIO-MIB.txt
UCD-DLMOD-MIB.inc
UCD-DLMOD-MIB.txt
UCD-IPFILTER-MIB.inc
UCD-IPFILTER-MIB.txt
UCD-IPFWACC-MIB.inc
UCD-IPFWACC-MIB.txt
UCD-SNMP-MIB-OLD.txt
UCD-SNMP-MIB.inc
UCD-SNMP-MIB.txt
UDP-MIB.txt
I copied to that directory the next mibs:
CISCO-FIREPOWER-EQUIPMENT-MIB.txt
CISCO-FIREPOWER-MEMORY-MIB.txt
CISCO-FIREPOWER-MIB.txt
CISCO-FIREPOWER-PROCESSOR-MIB.txt
When I try to get those values, I get an error.
root@FireSIGHT-Management:/usr/share/snmp/mibs# snmpwalk -v 2c -c XXXXX 10.3.51.40 .1.3.6.1.4.1.9.9.826.1.50
SNMPv2-SMI::enterprises.9.9.826.1.50 = No Such Object available on this agent at this OID
Has somebody be able to monitor a virtual Firesight?
It is running v6.2.3.4
09-18-2018 03:54 AM
Hello
To monitor CPU usage, I guess I have to use:
root@FireSIGHT-Management:/usr/share/snmp/mibs# snmpwalk -v 2c -c XXXXXX 10.3.51.40 1.3.6.1.2.1.25.3.3
HOST-RESOURCES-MIB::hrProcessorLoad.196608 = INTEGER: 6
HOST-RESOURCES-MIB::hrProcessorLoad.196609 = INTEGER: 3
HOST-RESOURCES-MIB::hrProcessorLoad.196610 = INTEGER: 3
HOST-RESOURCES-MIB::hrProcessorLoad.196611 = INTEGER: 5
12-03-2018 07:26 AM
What is "Load avg"? what paramether is monitoring??
12-04-2018 01:28 AM
At first you have to upload the global mibs
• CISCO-FIREPOWER-MIB.my
• CISCO-FIREPOWER-TC-MIB.my
• CISCO-FIREPOWER-FAULT-MIB.my
• CISCO-FIREPOWER-NOTIFS-MIB.my
Then you can use the other mibs in the package
Best Regards Thomas
12-04-2018 01:30 AM
03-14-2020 01:02 PM
How to get those MIB ?
It's seems impossible to obtain
Mario...
08-28-2017 03:36 PM
Please refers to Cisco FXOS MIB Reference Guide
04-05-2020 07:28 AM
Why aren't those MIBs in the Cisco MIB Locator? That URL shows how to download the whole FTD image, are we supposed to some how extract MIBs from an FTD image?
09-18-2018 05:32 AM - edited 09-18-2018 05:35 AM
12-04-2018 11:42 PM
But our sensors are the models 8140 and 8350. (not 4100/9300).
I can not find the MIB for these models.
