SNMP traps in MIBs are to generic
Wriswith01
I am working in a network with many cisco devices. Recently we changed to a new monitoring system which works heavily with SNMP traps. For most traps I was able to find the MIBs, but some traps that are being sent have a more specific OID than the ones defined in the mibs.
Here is an example:
This is the trap that I receive:
enterprise:.1.3.6.1.2.1.14.16 generic:6 specific:13 from a cisco VPN device
These traps are  defined in the mib on the Cisco website:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.2.1.14.16#oidContent
.iso(1).org(3).dod(6).internet(1).mgmnt(2)
     mib-2(1)
          ospf(14)
               ospfTrap(16)
                    ospfTrapControl(1)
                    ospfTraps(2)
                    ospfTrapConformance(3)
So as far as I can see the official Cisco documentation only goes up to 1.3.6.1.2.1.14.16 generic 3.
My question: Is the Cisco documentation outdated, or shouldn't my Cisco device be sending these traps?
Dan Frey
Are you sure your new NMS tool is displaying the entire trap and associated varbinds?   OSPF-TRAP-MIB looks like this on my system when sent from an isr router.
2011/12/23 - 19:04:32 TRAP: 0.0 from 0.0.0.0
    UDP: [192.168.0.1]:49798->[192.168.0.125] - isr, TRAP2, SNMP v2c, community public
    EXPRESSION-MIB::sysUpTimeInstance = Timeticks: (450248779) 52 days, 2:41:27.79
    SNMPv2-MIB::snmpTrapOID.0 = OID: OSPF-TRAP-MIB::ospfTraps.16
    OSPF-MIB::ospfRouterId = IpAddress: 192.168.99.1
    OSPF-MIB::ospfIfIpAddress = IpAddress: 192.168.0.1
    OSPF-MIB::ospfAddressLessIf = INTEGER: 0
    OSPF-MIB::ospfIfState = INTEGER: down(1)
To get more info look at OSPF-TRAP-MIB::ospfTraps.16 and figure out what is 16 in the OSPF-TRAP-MIB.traps file.
$ more OSPF-TRAP-MIB.traps
### THIS FILE WAS GENERATED BY MIB2SCHEMA
enterprise 1.3.6.1.2.1.14.16.2
    16 ospfIfStateChange
    1 ospfVirtIfStateChange
    2 ospfNbrStateChange
    3 ospfVirtNbrStateChange
    4 ospfIfConfigError
    5 ospfVirtIfConfigError
    6 ospfIfAuthFailure
    7 ospfVirtIfAuthFailure
    8 ospfIfRxBadPacket
    9 ospfVirtIfRxBadPacket
    10 ospfTxRetransmit
    11 ospfVirtIfTxRetransmit
    12 ospfOriginateLsa
    13 ospfMaxAgeLsa
    14 ospfLsdbOverflow
    15 ospfLsdbApproachingOverflow
16 = ospfIfStateChange.  Find this in the OSPF-TRAPS-MIB.my file.
     ospfIfStateChange NOTIFICATION-TYPE
          OBJECTS { ospfRouterId, -- The originator of the trap
             ospfIfIpAddress,
             ospfAddressLessIf,
             ospfIfState   -- The new state
          STATUS       current
          DESCRIPTION
             "An ospfIfStateChange trap signifies that there
             has been a change in the state of a non-virtual
             OSPF interface.  This trap should be generated
             when the interface state regresses (e.g., goes
             from Dr to Down) or progresses to a terminal
             state (i.e., Point-to-Point, DR Other, Dr, or
             Backup)."
          ::= { ospfTraps 16 }
The OID has 4 varbinds of
ospfRouterId
ospfIfIpAddress,
ospfAddressLessIf,
ospfIfState
Make sure the trap received has all the associated varbinds.
Dan
Well the traps are generated very rarely and I don't have direct access to the device. But I can post the all the information my system gives me.
Trap .1.3.6.1.2.1.14.16.1.6.12
Received unformatted enterprise event (enterprise:.1.3.6.1.2.1.14.16 generic:6 specific:12). 5 args: .1.3.6.1.2.1.14.1.1="176327880"
.1.3.6.1.2.1.14.4.1.1="0"
.1.3.6.1.2.1.14.4.1.2="3"
.1.3.6.1.2.1.14.4.1.3="176327784"
.1.3.6.1.2.1.14.4.1.4="176327880"
Trap .1.3.6.1.2.1.14.16.1.6.13:
Received unformatted enterprise event (enterprise:.1.3.6.1.2.1.14.16 generic:6 specific:13). 5 args: .1.3.6.1.2.1.14.1.1="176327880"
.1.3.6.1.2.1.14.4.1.1="1"
