SNMP Troubles on Cisco Equipment
Mark3000
I am using Cisco MWAM card as GGSN.
I am also collecting SNMP data via some Perl scripts. My problem is simple, some times, it looks that the MWAM is not responding to my SNMP GET REQUEST.
When doing a debug SNMP on the node, I have seen some messages like
Timer HC Fired
Timer HC Rearmed
Timer Delayed
etc.
I would like any help regarding the following points:
- How to decode these debug messages (meaning of each message ) ?
- Is it normal that the MWAM not respond some times to my SNMP GET REQUEST or respond with NULL value ? Why ?
- Any other help is welcome.
Best Regards
steve.busby
Level 5
Level 5
Mark,
I'm not familiar with your hardware, but if these devices are under a great load of network traffic, SNMP get requests will get dropped (SNMP normally runs at a much lower priority).
Can you verify how busy your device is? If you are debugging SNMP on the device itself--this could raise your cpu/memory utilization quite a bit.
You might want to look at putting a sniffer or ethereal on the link for your SNMP network management station.
Steve
