SNMP
ouhakheme
Level 3
Level 3
Is there any way to find out what all of the SNMP MIBs available on a Cisco Router/Switch do? I'd like to monitor the equipment, but I'm not sure if I need or don't need some of the information, and I'd like to know if I could decipher the information.
Please let me know.
Thank you.
farkascsgy
Level 4
Level 4
You can check with the following command:
show snmp mib
bye
FCS
Please rate me if I helped.
David Stanford
You can use Mibs in Images to show all the MIBs found in your device/image:
http://tools.cisco.com/Support/SNMP/do/MIBSupport.do?local=en&step=3
Also, have a look at:
www.cisco.com/public/mibs
you can select a device here and see the mibs it contains
