SNMP
KaliRathinam
How will check SNMP is working or not in a cisco router without using any managment tool? Is there any CLI?
miheg
Level 5
Level 5
You will some application to send snmp packets to the router.
On the router you can do a debug ip snmp packets
That will tell you if you receive anything on the router.
Cheers,
Michel
