snmpv3 Snmpset on Nexus 6000
avanzaadmin
I am having trouble getting snmpset to work on our nexus 6k's, more specifically ccCopyEntry (http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.9.96.1.1.1.1.&translate=Translate&submitValue=SUBMIT&submitClicked=true).
Snmpwalk works fine and I know that the credentials are correct.
After some troubleshooting I find the following:
show snmp trace-buffer pdu | i 6.1.4.1.9.9.96.1.1.1.1.14.1
[01/25/17 13:50:36.301 CET 1b4be978 3933] NO Handler for [iso.3.6.1.4.1.9.9.96.1.1.1.1.14.1] req[1241364658]
Doing a debug I get the following output:
2017 Jan 25 12:45:41.177930 snmpd: SNMPPKTSTRT: 3.000000 163 1341061666.000000 190786963.000000 0.000000 0.000000 0 4 3 2 0 ******** 0 remote ip,v4: snmp_55563_10.87.1.106 \200 11 0 \200 11 SNMP_USER 9 0 0 0x8954ff4 84
2017 Jan 25 12:45:41.178027 snmpd: vacm_in_view : securitylevel is 2 vs 3 for user SNMP_USER
2017 Jan 25 12:45:41.178046 snmpd: netsnmp_handle_request : netsnmp_handle_request: snmp_get_context_map_entry for returned invalid entry
2017 Jan 25 12:45:41.178124 snmpd: vacm_in_view : securitylevel is 2 vs 3 for user SNMP_USER
2017 Jan 25 12:45:41.178142 snmpd: is_subtree_allowed: msg_type is 163, subtree_len is 15, and oid is .1.3.6.1.4.1.9.9.96.1.1.1.1.2.1
2017 Jan 25 12:45:41.178154 snmpd: vacm_in_view : securitylevel is 2 vs 3 for user SNMP_USER
2017 Jan 25 12:45:41.178169 snmpd: is_subtree_allowed: msg_type is 163, subtree_len is 15, and oid is .1.3.6.1.4.1.9.9.96.1.1.1.1.2.1
2017 Jan 25 12:45:41.178458 snmpd: set_ccCopyProtocol : Entering RESERVE1 of entry (index = 1) : The protocol being set = 4
2017 Jan 25 12:45:41.178523 snmpd: set_ccCopyProtocol : Entering RESERVE2 of entry (index = 1)
2017 Jan 25 12:45:41.178608 snmpd: SNMP Operation (SET) failed. Reason:2 reqId (1341061666) errno (42) error index (1)
Does anyone know what the "NO Handler" means? Am I missing a Mib?
some Configuration:
snmp-server user SNMP_USER network-admin auth md5 PASSPHRASE
show snmp group
Role: network-admin
Description: Predefined network admin role has access to all commands
on the switch
Rule   Perm       Type      Scope      Entity
1       permit      read-write
0 Replies 0
