09-05-2008 02:10 PM
When i'm trying to config snmpv3 to a devices, i didn't see write or read privileges like snmpv2c?
Does snmpv3 read only privilege?
Thanks in advance
Abd Alqader
Solved! Go to Solution.
09-05-2008 02:15 PM
You can assign a write view to an SNMPv3 group. For example:
snmp-server group v3group v3 auth write v1default
This will allow any user in this group to write all typical read-write or read-create objects.
09-05-2008 02:15 PM
09-05-2008 02:18 PM
Thanks.
I got it.
I need to add write to the default view (v1default).
I tried before another new view name and i didn't get write privileges.
Thanks again
09-05-2008 02:21 PM
You can create your own view if you want to limit write access to only certain objects. However, you must define that view name before it will work.
