SNMS login
MathieuJM_2
We are using SNMS 1.5 on Windows 2003 server.
When i logged into the web site i need to log into the SNMS portal, that's okay.
But as soon as i'm logged into SNMS i must login again this time for the Whats Up web page.
Is it possible to have access to the WhatsUp web page without having to log again ? I mean having a kind of SSO ?
Cheers
Joe Clarke
On the SNMS server, go to Start > Program Files > WhatsUp Gold. Once WUG launches go to Configure > Web Server > Users, and unselect "Enable Web Security". you should then only be prompted for the Common Services username/password.
Many thanks for your answer.
