Standard Checklist
joseph.derrick
In checking Cisco devices such as routers, switches, firewalls, etc ... what are the recommended checks that should performed on the devices to check if the equipments are healthy or not ?
k0rg
aghaznavi
Level 5
Level 5
Check list for Router, Switch & Firewall.
1. Verify your hardware.
2. Verify your IOS Image.
3. Verify the power supply.
4. Verify all the ports are operating.
5. Verify IOS image.
6. Use troubleshooting commands to verify your devices.
