Startup and Running Out-Of-Sync Summary
p950mte
Hello! In "Out-Of-Sync Summary" RUNNING cfg is dated Feb 03 2009 04:14:27 and Startup is dated Feb 24 2009 04:13:55, how can it be that Running cfg is older than Startup cfg? Configuration Last archived Time Feb 03 2009 04:14:27,Inventory Last Collected Time Feb 26 2009 00:33:32, how do i manage best this part of RME? Regards Mats!
akemp
Level 5
Level 5
Its very easy to do that, you only have to tftp a startup-config to the device and not reload it.
"Fixing" it the easiest way is to create a reoccurring ad hoc job with one line "write memory"
in 3.x forwards there's a fix it button :)
Ok, thank you! You have the option of synch archive in 2.6, what i'm thinking of is how Running cfg can be older than startup cfg? (copy running to startup without wr mem?) Not in most cases but in few..
//Mats
