Supported Endpoints
Dean O'Meara
Does anyone know if the below endpoint is supported for reporting / monitoring in PCM?
  • Cisco SX20
Kind regards.
Marvin Rhoads
Assuming you are asking about Prime Collaboration Manager, the answer is yes for Version 1.2.
You can see all the supported devices in the compatibility information tables posted here:
http://www.cisco.com/en/US/products/ps11480/products_device_support_tables_list.html
Hi Marvin.
Thanks for the reply.
Sorry, I meant this is for Cisco Prime Collaboration Version: 9.5.34267
Same process, different page - have a look at the product support page for Cisco Prime Collaboration (9.0 and 9.5):
http://www.cisco.com/en/US/products/ps12363/products_device_support_tables_list.html
It appears the SX20 is supported as an assurance endpoint:
http://docwiki.cisco.com/wiki/Supported_Devices_for_Cisco_Prime_Collaboration_Assurance_9.5
