Syslog collector prob.
ahmed.elshikh
Dear all,
I'm facing a problem in Local management system (LMS) as this message appears when we check on the syslog status :
SLCA0132: Collector Status is currently not available.
Check whether the SyslogAnalyzer process is running normally.
, and I can't receive any syslogs. Please I need your help.
thx.
AFROJ AHMAD
Hi Ahmed,
try the below stesp::
-pdterm SysCollector
-pdterm SyslogAnalyzer
then
pdexec Syslog Analyzer
pdexec SyslogCollector
Also make sure ,UDP port no. 514 is not blocked
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
