Syslog entry on enable event
e-alvarez
Level 2
Level 2
Is there any way to send a message to a Syslog server when a user goes into privileged mode (enable)?
Joe Clarke
You can use the command "logging userinfo" (assuming your IOS supports it) to do this. When a user enables oneself, the following message will be printed:
%SYS-5-PRIV_AUTH_PASS: Privilege level set to 15 by USER on LINE (IP)
Thanks, Joe
I just tried it and it worked like a charm!
