Syslog issue
nawas
Level 4
Level 4
I have installed a fresh copy of LMS3.0 on Solaris 10 but I don't get any syslog reports. When I go in var/log/syslog_info there are no messages in the file. Do I need to update anything else for syslog to get the messages in syslog_info?
24 Replies 24
Restarted syslogd, regenerated the message but stil it didn't make it to syslog_info. I have attached the snoop capture.
Post the output of ps -efl and netstat -an.
Here it is
one more file
Syslog is running, but not bound to udp/514. Post the output of:
svcprop svc:/system/system-log:default
Here is the output
This is what I thought. Your syslog service is not configured to allow remote message reception. Run these commands as root:
svccfg -s svc:/system/system-log setprop config/log_from_remote = true
svcadm refresh svc:/system/system-log
Then you should be receiving remote messages.
nop that didn't work, stil no syslog. Here is the updated svcprop
Joe Clarke
Try forcing a restart of syslogd:
svcadm disable svc:/system/system-log
svcadm enable svc:/system/system-log
That did it. It's working now.
Thanks a lot for all your help Joe. I knew you would resolve it.
