syslog problem
vinay_8812
my 3 core routers are config. for sending syslog to LMS server. only one 3660 is sending syslog. rest two 3660 and 7609 is not sending log.
the config for syslog is
logging on
logging "LMS server IP"
what is the problem
farkascsgy
Level 8
Level 8
Set also the level of logging with
logging trap "level"
command. (eg. to logging trap debugging)
bye
FCS
Please rate me if I helped.
David Stanford
This config should work and send messages at the default level. You might want to try and generate a syslog message from a failing device which enabling a packet capture from the syslog server. You can then see if the messages are making it to the server or blocked somewhere along the way.
