Syslog viewer
subashmbi
Dear All,
In LMS any software is for viewing the syslog files.
Joe Clarke
Viewing the raw syslog.log file? No. You can use a text reader to do that.
However, you can view the messages which RME has processed, and added to its database by running the various syslog reports under RME > Reports > Report Generator.
Thanks Clarke,
If the log size is more than 2gb, the text reader will not support, any other tool can support this large files to open.
I know quite a few Windows users who like Ultra Edit (http://www.ultraedit.com/ ). You can download an eval to try out. I myself like Vim (http://www.vim.org/download.php ), but it's an acquired taste. Both are capable of opening large files.
