Tacacs+ custom attributes disappear?!
OLOF SAMUELSSON
Hi, I'm running ACS 4.1(4) Build 13 Patch 1
and a weird thing is happening:
I need to make a user an admin on a nexus switch, so I'd like to add the Tacacs+ custom attribute cisco-av-pair*shell:roles=”network-admin” to the user.
I can do that all right, submit it with out any error message but when I look at the user right after that the custom attribute box is blank and both the custom attributes and "Shell" checkboxes are cleared. I have no idea where to start looking, anyone have any clues?
/Olof
Jagdeep Gambhir
Level 10
Level 10
Please update your Java and then try. Also you can try different browser.
~JG
Do rate helpful posts
Thanks, but it did not help.
I was already running 1.6.0_16 and tried with both IE6 and Firefox and also attempted to edit it with IE6/JRE 1.5.0_12.
Still disappears.
Thanks anyway for the effort!
/Olof
