TcL extended ping script?
juan_6_810
I have been looking online to try and find a way to automate extended pings with the record option, but have only found some that are for regular pings.
This is one of the ones that I found:
foreach address {
x.x.x.x
x.x.x.x
x.x.x.x} { ping $address repeat 10 size 1500
My question is, would simply adding "record" to the script work?
Thanks in advance,
Juan.
Joe Clarke
No.  The record option cannot be specified directly on the command line.  You can use EEM Tcl to do what you want.  The attached script will work.  Edit it to replace the "x.x.x.x" with your IPs.  Copy this script to a directory on flash (flash:/policies), then configure:
event manager directory user policy flash:/policies
event manager policy ping_record.tcl
Run the script with the EXEC command:
event manager run ping_record.tcl
Joe Clarke
Thanks.
if { [catch {cli_write $cliarr(fd) "ping ip"} result] } {
error $result $errorInfo
How do I modify this line if my original command is ping 10.172.1.1 so 10.200.1.1?
"ping $ip so 10.200.1.1"?
Jack
jacknew2005@gmail.com
