08-29-2007 06:38 AM
Where can I get the TCL Library? I guess that problem "unknown namespace in import pattern "::cisco::eem::*" can be resolved with a help of the TCL Library.
08-29-2007 08:21 AM
That namespace is only available to EEM TCL policies. It is not available to tclsh scripts. The EEM modules are stored in a protected region of memory on the device at tmpsys:/lib/tcl. You may also find it system:/lib/tcl on older versions of IOS. You can download those scripts, and modify them to work in your scripts. Some can even be used directly.
08-30-2007 02:50 AM
Thank you for your help.
