Telemetry - Stream won't connect to reciver
no_prop4500
We have a 4451 that won't for the life of me connect the yang-push subscription to the receiver. I've built the subscription over and over, it just wont connect. When capturing on the server or the router, I don't even see push packets for the subscription. I know the telemetry stack is working as it's receiving telemetry data from other routers. The other kicker is when using the 'Advanced Yang-Explorer' requesting the telemetry data from there, works! Any ideas would help, thanks!
Topology:
*4451* -> Telegraf -> Influx
Config:
#sh telemetry ietf subscription 101 de
Telemetry subscription detail:
  Subscription ID: 101
  Type: Configured
  State: Valid
  Stream: yang-push
  Filter:
    Filter type: xpath
    XPath: /interfaces-ios-xe-oper:interfaces
  Update policy:
    Update Trigger: periodic
    Period: 200
  Encoding: encode-kvgpb
  Source VRF:
  Source Address: 10.x.x.x
  Notes:
  Receivers:
    Address          Port             Protocol         SecurityProfile
    10.x.x.x    57000            grpc-tcp
#sh telemetry ietf subscription 101 re
Telemetry subscription receivers detail:
  Address: 10.x.x.x
  Port: 57000
  Protocol: grpc-tcp
  Security profile:
  State: Disconnected
  Explanation: Connection setup failed
0 Replies 0
