TFTP: error code 2 received - 16739
Joel Cagle
Frequent Visitor
Frequent Visitor
Hello All,
          I have a slight problem with my archive settings. I have a number of switches on the same subnet archiving to the same tftp server. On one of my switches (and only one) I get the error "TFTP: error code 2 received - 16739" (it is not followed by the normal %Error opening....permission denied% statement)
Here is the strangest part if I do a copy running-config tftp:  The config copies just fine, but the archive still gives the tftp error. any suggestions would be most appreciated.
here is my archive config (the IP has been changed for security reasons)
archive
 path tftp://192.168.5.5/$h-$t
 write-memory
 time-period 43200
TLDR
Community Member
Had a similar problem.
Swapped:
path tftp://IP-ADDRESS/$h-$t
With:
Archive path is picky with that command.
Yea. path tftp://IP-ADDRESS/$h is worked for me.
Thanks a lot TLDR.
