Timed port shut no shut help
Neil spur
Hi, I have a Poe switch that I need to configure to shut a port at a specific time and enable it the next day. Was looking at timed ACL but I understand this only denies protocols and not the port. Just started to read about eem. Is this the way forward ? I have searched for anything similar I can use and I’m out of my depth especially the tcl Side of things.
Any advice appreciated.
3 Accepted Solutions
I think the 2960X does not fully support EEM. You should be able to do this with TCL and Kron. I'll test and get back with you...
here are two scripts that should work. The first one will shut interface GigabitEthernet0/0 at 17:00 each day, the second one will unshut it at 08:00 each day. Change the interface number and the time to what applies to you. Also, my device uses 'flash0', yours might just be named 'flash'...
2960X#tclsh
puts [open "flash0:shutdown_port.tcl" w] {
set ports [lindex $argv 0]
ios_config "int $ports" "shut" "end"
tclquit
config t
kron policy-list policy_shutdown_interface
cli tclsh flash:shutdown_port.tcl "GigabitEthernet0/0"
exit
kron occurrence policy_shutdown_interface at 17:00 recurring
exit
exit
wr mem
2960X#tclsh
puts [open "flash0:unshut_port.tcl" w] {
ios_config "int $ports" "no shut" "end"
tclquit
config t
kron policy-list policy_unshut_interface
cli tclsh flash:unshut_port.tcl "GigabitEthernet0/0"
exit
kron occurrence policy_unshut_interface at 08:00 recurring
exit
exit
wr mem
6 Replies 6
You can use EEM script.
 This is not new here in the forum. Take a look here:
https://community.cisco.com/t5/network-management/eem-script-shutdown-interface-at-a-certain-time/td-p/4504788
Neil spur
Thank you for your time.
Neil spur
Slight update as the link sent me to a script for a diiferent system. I have a cisco WS-C2960X-24PS-L running c2960x-universalk9-mz.152-2.E6 ios.
In conf t i don't have the event command.
2960X#tclsh
tclquit
config t
exit
exit
exit
wr mem
2960X#tclsh
tclquit
config t
exit
exit
exit
wr mem
Neil spur
You sir are a magician…
hats off to the people who can come up with this stuff. I thought doing a ccna was tough.
Awesome work fella,
