Tomcat Servlet stopped unexpectedly
js88888888
Looks like this service stops and will not come back after daemon restarts or system reboots.
Attached is the log that seems to be pertinent. Anyone know why this is happening?
thanks
Joe Clarke
There doesn't appear any errors here which leads me to believe the VM is dying. There should be some hs_* files lying around NMSROOT\MDC. Please post the most recent.
Here is the latest I found. Thanks Jclarke.
It looks like your NMSROOT\MDC\etc\regdaemon.xml file has either become corrupt, zero bytes, or casuser no longer has permission to read this file. If the permissions are correct, then you will either need to restore a known good backup, or reinstall LMS from scratch.
Thanks, that did it. I restored that xml file and its working.
