track inside ip address bandwidth use
hellasnow
is there a way with a cisco pix 501 using Cisco Pix Device Manager 3.0?
smahbub
Level 6
Level 6
Interface graphs-Provide real-time monitoring of your bandwidth usage for each interface. Bandwidth usage is displayed for incoming and outgoing communications. You can view packet rates, counts, and errors, as well as bit, byte, and collision counts, and more.
check the section "Monitoring>Interface Graphs" in the document present in the following url:
http://www.cisco.com/en/US/docs/security/pix/pix63/pdm30/olh/PDF_Version_-_PDM_OLH/pdm30olh.pdf
sorry to be more specific i want to be able to track each machine's IP bandwidth useage not just the main internal or external ip.
