Trouble finding OIDs for 2960x switch
Michael McGrath
I have a stack of 2960x switches are I am monitoring them using OID values. However, I am having trouble finding the OIDs for the individual switches in the stack. For example, when I use the OID 1.3.6.1.4.1.9.9.109.1.1.1.1.5 (object pmCPUTotal5min) or 1.3.6.1.4.1.9.2.1.58 (object avgBusy5) it only pulls one value and I found that this value is only of the master. How am I supposed to monitor the other switches in the stack? I haven't found the correct OID for CPU, Memory, or flash usage, but I have found the OIDs for each switch for the temperature value.
Mark Elsen
 http://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/15215-collect-cpu-util-snmp.html#multiple
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for your response, Marce1000.
I have 6 2960x in a stack and when I run snmpwalk with the OID in that link (.1.3.6.1.4.1.9.9.109.1.1.1.1.5) it only shows one CPU instead of the 6 I would expect.
snmpwalk -v2c -c public 10.X.X.X .1.3.6.1.4.1.9.9.109.1.1.1.1.5
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.1 = Gauge32: 32
