Trying to get CiscoView device manager to work on 6500
pipsadmin
I downloaded 2 files from cisco:
cvdm-c6500chassis-19.0.tar
and
cvdm-c6500-1.1.tar
I started to install " archive " command from tftp to bootflash:
Made sure there was enough space on bootflash.
the HTTP config is:
ip http server
ip http authentication local
ip http path bootflash:
I have several users configure on this switch, yet when I try to login with one of the users, I get an invalid userna,e or password...?!?
Line vty 0 4 is setup as :
line vty 0 4
access-class 101 in
exec-timeout 9 0
privilege level 0
password 7 xxxxxxx
transport preferred ssh
transport input lat pad mop udptn telnet rlogin ssh nasi acercon
Why can't I login?
Joe Clarke
What version of code, and what supervisor? CVDM is more or less dead, and will not work with newer versions of code, and newer supervisors. It is recommended you move to CiscoWorks LAN Management Solution with CiscoView.
