Turning on IP Routing
If, on a layer three switch, i turn on ip routing, without doing anything else, will it continue to behave as it has been, acting as an access switch?
luis_cordova
Hi haggittmark@tm-america.com
By entering the ip routing command, you enable the layer 3 functions of the switch, so if you have configured virtual interfaces (SVI) they will start to communicate with each other, just like in a router.
