Unable to archive config using SSH, RME 4.3.1
shyams
I am not able archive config for Nexus 5020 switches using SSH. I have already change TuneSleepMillis to 500 and applied the workaorund for bug CSCte98853 .
CSCte98853 Bug Details
RME cannot archive configs for NEXUS 5000 and 7000 devices
Symptom:
RME 4.3 doc says NEXUS 5000/7000 are all supported, but automated actions for config archives do not work. This is because the NEXUS devices use a different form of syslog format:
"%VSHD-5-VSHD_SYSLOG_CONFIG_I:"
RME's existing Config_Fetch automated action should add this syslog in the future versions.
Conditions:
This affects all RME versions up to 4.3.1.
Workaround:
Steps to add the message format:
a) Navigate to Tools --> Syslog --> Automated Actions
b) Select the "Config Fetch" and click on edit
c) Don't change on the next screen. Click "next" to proceed to
"Define Message Type" wizard
d) Click on "Add" button then fill the following details as follows:
a. Facility - VSHD
b. Sub-facility - *
c. Severity - 5
d. Mnemonic - VSHD_SYSLOG_CONFIG_I
e. Description - *
Then restart the SyslogAnalyzer daemon
The problem still persists.
I have attached dmcaservice log.
shyams
I had to change TuneSleepMillis=1000 and reloaded my server once. All is fixed now.
