Unable to get lightweight APs booted
BDH
I don't have (much) experience with cisco APs, but still I need to get a few AP's linked to a WLC - that's being managed by one of our partners.
So I received a few AP's and I factory reset them by holding the mode button, connecting PoE and releasing when the console told me to. So far so good, but now 2 of the 3 AP's are stuck in the "AP" menu and the 3th one doesn't apply any config + says "%LWAPP-3-CLIENTERRORLOG: Config load from flash failed."
Below is a copy of the dirs:
AP1:
ap: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
                tftp[5]: (read-only)
ap: dir flash:
Directory of flash:/
2    -rwx  78492     <date>               event.log
26   -rwx  1048      <date>               private-multiple-fs
4    -rwx  64        <date>               sensord_CSPRNG0
5    -rwx  64        <date>               sensord_CSPRNG1
6    -rwx  104       <date>               pnp-saved-config
45   drwx  320       <date>               configs
24   -rwx  283       <date>               info
82   -rwx  173       <date>               env_vars
8    drwx  2432      <date>               ap3g2-k9w8-mx.153-3.JD13
84   -rwx  0         <date>               ce
13   drwx  192       <date>               ap3g2-rcvk9w8-mx
95   drwx  768       <date>               c1140-k9w7-mx.153-3.JD11
662016 bytes available (31335936 bytes used)
ap:
AP2:
ap: dir
ap: dir flash:
2    -rwx  282       <date>               info
3    -rwx  64        <date>               sensord_CSPRNG0
8    drwx  768       <date>               c1140-k9w7-mx.153-3.JD11
5    drwx  512       <date>               configs
6    -rwx  280       <date>               lwapp_officeextend.cfg
7    -rwx  64        <date>               sensord_CSPRNG1
227  drwx  2496      <date>               ap3g2-k9w7-mx.153-3.JF5
466  -rwx  174       <date>               env_vars
78   -rwx  146       <date>               capwap-saved-config
79   -rwx  0         <date>               ce
84   -rwx  1950      <date>               atf_override_config_slot0.txt
88   -rwx  1950      <date>               atf_override_config_slot1.txt
8727552 bytes available (23270400 bytes used)
ap: vers
C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JAY, RELEASE SOFTWARE (fc1)
Compiled Thu 03-Oct-13 03:35 by sdcunha
AP3 (the one that boots through, but gives the config load failed error:
AP7426.ac1a.cf59#dir
    2  -rwx         337   Jan 1 1970 00:08:08 +00:00  info
    3  -rwx          64  Mar 15 2018 11:53:26 +00:00  sensord_CSPRNG0
   32  drwx         448   Mar 1 1993 00:03:18 +00:00  ap3g2-rcvk9w8-mx
    4  -rwx       90649   Mar 1 1993 06:10:05 +00:00  event.log
    5  drwx         448   Mar 1 1993 00:00:14 +00:00  configs
    6  -rwx           0   Mar 1 1993 00:00:33 +00:00  config.txt
    7  -rwx          64  Mar 15 2018 11:53:26 +00:00  sensord_CSPRNG1
   11  -rwx        1048   Mar 1 1993 00:00:19 +00:00  private-multiple-fs
   51  -rwx         226   Mar 1 1993 06:09:59 +00:00  env_vars
   54  -rwx       60586  Mar 13 2018 00:40:36 +00:00  event.capwap
   82  -rwx        1950  Jan 16 2017 15:05:16 +00:00  atf_override_config_slot0.txt
   86  -rwx         104  Feb 28 2014 00:25:00 +00:00  pnp-saved-config
   78  -rwx         145   Jun 7 2018 07:24:46 +00:00  capwap-saved-config
   90  -rwx      141621   Dec 6 2017 11:23:41 +00:00  event.r1
   83  -rwx        1950  Jan 16 2017 15:05:16 +00:00  atf_override_config_slot1.txt
   88  -rwx      131476   Aug 6 2018 06:27:54 +00:00  event.r0
   89  -rwx           0   Oct 6 2016 10:39:08 +00:00  ce
   97  -rwx         145  Mar 24 2019 15:10:42 +00:00  capwap-saved-config-bak
  100  -rwx       95008  Mar 15 2018 11:48:57 +00:00  lwapp_reap.cfg.bak
    8  drwx        2496  Feb 21 2018 15:41:46 +00:00  ap3g2-k9w8-mx.153-3.JD13
  101  -rwx           8   Aug 3 2018 14:45:31 +00:00  sensord_crashVer0
  103  -rwx       32793   Aug 3 2018 14:45:31 +00:00  sensord_crashFile0
31739904 bytes total (8691200 bytes free)
ap: vers
ap:
AP7426.ac1a.cf59# sho version
Cisco IOS Software, C2600 Software (AP3G2-RCVK9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:08 by prod_rel_team
ROM: Bootstrap program is C2600 boot loader
BOOTLDR: C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JAY, RELEASE SOFTWARE (fc1)
AP7426.ac1a.cf59 uptime is 38 minutes
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
Last reload reason:
 --More--
Not in Boagree to comply with applicable laws and regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2602I-E-K9 (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FCZ1814D174
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 74:26:AC:1A:CF:59
Part Number                          : 73-14588-03
PCA Assembly Number                  : 800-37899-01
PCA Revision Number                  : B0
PCB Serial Number                    : FOC18091Z9D
 --More--
*Mar  1 00:38:36.223: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. RenewinTop Assembly Part Number             : 800-38356-01
Top Assembly Serial Number           : FCZ1814D174
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP2602I-E-K9
Configuration register is 0xF
AP7426.ac1a.cf59#
Like I said, I don't really have experience with lightweight cisco AP's. Can someone help me with this, please?
22 Replies 22
Autonomous IOS file for the 2600/3600/2700/3700 can be found HERE.
To upload the IOS to the AP (in ROMMON), use the following method:
flash_init
load_helper set IP_ADDR <IP ADDRESS> set DEFAULT_ROUTER <GATEWAY> set NETMASK <NETMASK> tftp_init tar -xtract TFTP://<COMPUTER IP ADDRESS>/FILENAME.tar flash:
BDH
Thanks! I'll try this and update here as soon as I know the outcome
BDH
We recently bought a few plants in different countries => this AP thing I'm trying is for one of those plants => We don't have a service contract for these AP's, but looks like it is required to be able to download this software. Do you know another way how I can download the .tar file?
IMPORTANT:  Before engaging TAC, make sure to know what exact firmware version you want to download.
  1. Read this:  Multiple Vulnerabilities in Wi-Fi Protected Access and Wi-Fi Protected Access II
  2. Scroll down to the "Customers Without Service Contracts" section.
  3. Read the first two paragraphs very carefully.
Thanks for the help already. I called cisco and it looks like they don't want to help -> they don't want to provide me the software without a contract.
A colleague of mine found some image version he had "lying around". So I tried with that. Thanks to your help in your previous comments, I managed to get the image on the AP (it's again an 1141 image ). Below is the result:
extracting c1140-k9w7-mx.152-2.JB/c1140-k9w7-mx.152-2.JB (9233742 bytes)...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
extracting c1140-k9w7-mx.152-2.JB/8001.img (186220 bytes)........................................
extracting c1140-k9w7-mx.152-2.JB/T2.bin (8080 bytes).
extracting c1140-k9w7-mx.152-2.JB/T5.bin (23836 bytes).....
extracting c1140-k9w7-mx.152-2.JB/info (277 bytes)
extracting info.ver (277 bytes)ap:
ap: dir flash:c1140-k9w7-mx.152-2.JB
Directory of flash:c1140-k9w7-mx.152-2.JB/
226  drwx  64        <date>               html
9    -rwx  9233742   <date>               c1140-k9w7-mx.152-2.JB
13   -rwx  186220    <date>               8001.img
14   -rwx  8080      <date>               T2.bin
15   -rwx  23836     <date>               T5.bin
16   -rwx  277       <date>               info
19893248 bytes available (12104704 bytes used)
ap: boot flash:c1140-k9w7-mx.152-2.JB/c1140-k9w7-mx.152-2.JB
Rebooting system to reset DPAA...
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Macronix Mirrorbit (00C2)
Xmodem file system is available.
flashfs[0]: 554 files, 20 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 12104704
flashfs[0]: Bytes available: 19893248
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: d0:72:dc:3d:b9:19
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:c1140-k9w7-mx.152-2.JB/c1140-k9w7-mx.152-2.JB"...##############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
image.
ap:
How can I set this BOOT environment vairable to bootable?
The AP is a 2600 and you are forcing it to boot an IOS meant for an 1140.  It will not work.
For a 2600, it needs to boot an IOS specifically for a 2600/3600/2700/3700.
Do you know if there's a way to download the firmware/OS file from another existing AP in our network? Maybe through WinSCP or something?
In my humble opinion, your are only the second person I have known unable to get Cisco Entitlements Team to let "through the barricades" (and talk to TAC about publishing the firmware) using the method I have described above.
Other people I have helped were successful in getting TAC to publish the firmware without the need for a valid Service Contract.
