Unable to load webpages - ping to ip and domains are working
kit.mehta
Hi all,
After spending so many hours I am quite frustrated and asking this question..
Setup: - GNS3
GNS3 VM Cloud -> ASA firewall -> Ubuntu VNC clinet
Cloud 192.168.114.2
ASA Outside 192.168.114.10
ASA DMZ - 172.16.1.1
DMZ (Ubuntu) - 172.16.1.2
ACL - outside extended permit TCP any host 172.16.1.2 eq www and also added
Access-Group added to allow HTTP and https
I am able to ping the IP
I am able to ping domain i.e. google.com
I just cant get the webpages to load..
DNS added on client 8.8.8.8
Please help..
13 Replies 13
can you post the full running config of the ASA (ASAv that is I assume) ?
removed old configuration and attached pics of the new one below.. still the same issue
changed few things from last upload
Hi kit
Thank you for update
I cannot find access-group.
Did you enable access-group on DMZ interface?
And Is 172.16.1.2 the correct IP address of Webpage(Internet)?
2021-11-20 08_28_02-Window.png2021-11-20 08_27_30-Window.png2021-11-20 08_26_57-Window.png
I have reconfigured the ACL/Groups/NATs/routes - still no access to webpages
Hello
Did you configure HTTP?
example)
http server enable
http 0.0.0.0 0.0.0.0 inside(or outside)
please show me http and asdm configure
2021-11-20 08_34_05-Window.png2021-11-20 08_33_50-Window.png2021-11-20 08_33_32-Window.png2021-11-20 08_33_18-Window.png2021-11-20 08_32_57-Window.png2021-11-20 08_36_25-Window.png2021-11-20 08_35_46-Window.png2021-11-20 08_35_18-Window.png
i have attached the images of my config.. please advise
yes
kit.mehta
i have attached the images of my config.. please advise - also you may notice that the inside is also facing the same problem
