Updating DNAC
scottbreslin
Hi - I tried to update our DNAC today to the latest system update.  However, i am getting the following error:
System update failed during INSTALLED_CATALOG. b'Error: UPGRADE FAILED: Get "https://100.64.16.1:443/api/v1/namespaces/kube-system/configmaps?labelSelector=NAME%!D(MISSING)catalogserver%!C(MISSING)OWNER%!D(MISSING)TILLER": x509: certificate has expired or is not yet valid: current time 2023-05-25T10:54:32Z is after 2023-04-12T10:11:21Z\n'
Looking at the DNAC certificates, they all  appear to be valid.  The time is also correct on the server.
Can someone please assist.
Scott
Julio E. Moisa
I have not seen this error before, if the time is correct after a reboot I suggest open a case with the Cisco TAC.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
 Did you check the certificates with this command?
sudo maglev-config certs info
