Upgrade analysis
woods8
From RME>Software Mgmt>software distribution>upgrade analysis I have selected my specific devices and selected an IOS from my software repository but each time I run this I get "This device requires telnet access for image downloads. Please make sure device's telnet access information is configured and is accurate"
Telnet is working fine on these devices?
Any ideas?
I use LMS2.5, RME & CM 4.0.4, CS 3.0.4 on a windows server.
David Stanford
Do you have custom telnet prompts other than Username: and Password: ?
If you run a device credentials verification report are the values all returned ok?
David Stanford
Thanks for your reply.
No
I get ok on some of my devices but the others show "No value to test" ??
They all have telnet configured in the same way?
thanx
Hi Paul,
usually it means you have no values for these devices and protocols configured in the DCR.
Have a look in Device and Crendentials for some of you not working devices. If they have empty telnet and password fileds, this may be the problem.
Hope that helps,
Frank
That would explain why telnet is failing, the database has no value to send to the device. You should do an edit device credentials and enter all necessary fields (those that may be blank) and this should resolve your issue.
