Upgrade Cisco 2960S Stack switch using Cisco Prime
MSJ1
Need to upgrade a Cisco 2960S-48FPS. And want to use Cisco Prime to do the Code Upgrade.
As this is a stack is there any different step I need to follow from Cisco Prime ? I know software file extenstion will be .tar for stack switch  ?
In the Distribute Option section I see "Device Upgrade Mode" :: Does it have anything to do for Cisco 2960 Stack Switch  ?
Leo Laohoo
How many switches/stacks needed to be upgraded?
Every year, I do north of 900 stacks of switches without any automation.  I have never "lost" a switch stack.
Mark Elsen
 >In the Distribute Option section I see "Device Upgrade Mode" :: Does it have anything to do for Cisco 2960 Stack Switch
                                    Not specific , check this link for info about difference between the two Modes :
            https://www.lookingpoint.com/blog/ios-xe-catalyst-switches#:~:text=Bundle%20mode%20is%20simple.,image%20and%20reboot%20the%20switch.&text=Install%20mode%20is%20the%20default,package%2Dprovisioning%20file%20named%20packages.
 M.
