Upgrade from LMS 2.6 300 Node
charleseharris
We are currently running CW-LMS-2.6-R-K9 (Limited to 300 nodes) and need to managed 450+ devices. What options are open to me for an upgrade?
I believe all that's involved is pointing LMS to the new license file (.lic) via the browser GUI: Common Services > Server > Admin > Licensing. The Size column should reflect the new node count.
Name Version Size Status Expiration Date
1. CM 4.0 Unlimited Purchased Never
2. DFM 2.0 Unlimited Purchased Never
3. IPM 2.6 Unlimited Purchased Never
4. RME 4.0 Unlimited Purchased Never
yjdabear
Next step-up is CWLMS-3.0-1.5K-K9, unless you need to running multiple instances of LMS, in which case buying a single copy of CWLMS-3.0-5K-K9 might make more financial sense than multiple copies of CWLMS-3.0-1.5K-K9.
yjdabear
Oops, in case of LMS 2.6, the next step-up is the Unlimited version.
Thank you for the response, do you know if the upgrade to the LMS 2.6 Unlimited is a complete reinstall or just an easy license change?
