Uploading/Installing procedure for device packages in Cisco View/RME
Running LMS3.2 with HUM 1.2.
In cisco view when we tried for below mwntioned devices it says "Device Package for these device is not available".
WS-C2960S
CISCO2921
CISCO3945E.
Please let me know the link to download the device packages for above devices and the procedure to install it on LMS.
Thanks & Regards,
Krishna
AFROJ AHMAD
Hi Krishna,
Replace the attached file (vds.properties) in the below location :
NMSROOT\CSCOpx\lib\classpath\com\cisco\nm\xms\vds
then Restart the Daemon Manager ..
NOTE : Please take the Bcakup of your Existing file (vds.properties)
--Then    go to common service > software center > device update >>    check for the Device Pcakages , you will be able to see   the Device  Packages now..
Thanks--
Afroj
If this post answers your question, please click the "Correct Answer" button"
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Krishna,
Thanks--
Afroj
Hi Afroj,
Your solution worked!!!!
Thanks alot!!!!
Thanks & Regards,
Krishna
