11-09-2008 01:37 PM
I have configure the acqusition settings to: enable user tracking for DHCP enviroment, Get user names from hosts in NT and NDS domains,Use DNS to resolve host names but username still dont show when I do a query. Any ideas?
11-09-2008 02:52 PM
You need to be running the UTLite33.exe program on all of your Windows end hosts. This program will periodically send UDP packets to the Campus Manager server which contain the locally logged in username, as well as the end host's MAC and IP addresses.
More on setting up UTLite can be found by searching the Campus Manager online help for the string UTLite.
11-10-2008 06:52 AM
Sorry I forgot to mention that I am also running a script on all my computer so they run utlite every time they log in. I have running manualy on my computer just a as test and I still dont get any username.
11-10-2008 08:50 AM
What version of Campus Manager is this? Is UDP port 16236 open between the end hosts and the server?
11-10-2008 02:34 PM
5.03 is all intrnall, no ports are blocked.
11-10-2008 02:38 PM
Try restarting the UTLITE daemon on the server:
pdterm UTLITE
pdexec UTLITE
Then, go to one of the Windows end hosts that are already showing up in User Tracking, and logout, and log back in. Make sure UTLite33.exe was restarted. Then go to UT, and see if the username is showing up.
11-19-2008 09:52 PM
No luck. any other ideas?
11-20-2008 08:51 AM
You'll need to enable UTLITE tracing under Campus Manager > Administration > User Tracking > Debugging Options > Dynamic User Tracking. Enable TRACE for all UTLITE subsystems. Then, log out and log back into a workstation, and post the utlite.log.
11-22-2008 06:44 AM
11-22-2008 09:10 AM
According to this, you are not sending any UTLite packets from your clients to this server. Please post a sniffer trace showing a client sending a UTLite packet as well as a new utlite.log which covers the same time frame.
11-22-2008 04:29 PM
Should I be able to telnet to the Cisco Works server using port 16236?
11-22-2008 04:49 PM
11-22-2008 05:48 PM
There are no udp/16236 packets here. The way UTLite works is that when the user logs in on the client, the domain controller copies down a UTLite33.exe file. As part of the user's login script, a UTLite.bat is run. This batch file starts the executable. This executable in turn sends udp/16236 packets to the Campus Manager server every 10 minutes.
If you have setup your login script to do the copy and spawning of UTLite, then the UDP packets are not making it from the client to the server. If you have any firewalls or access-lists, make sure they are permitting udp/16236 from every Windows client to the LMS server.
11-22-2008 06:28 PM
There is no firewalls in the middle or access list.I will leave the wireshark running for a good hour to see if I catch anything
